Three times in the past 5 days I’ve experienced a blue screen “DRIVER POWER STATE FAILURE”. Any solutions?
Please carefully describe your problem, including product model, product serial number, and send it to service@chuwi.com.
You can try reinstall battery and charger driver or see in bluescreenview which file cause problem.
I have done that it’s definitely the network adapter causing a problem. This morning it turned on fine but would not connect to the wifi. Reset the network adapter and re started and got the same blue screen, now it has connected fine.
