Can I upgrade/replace an N100 to an N150 motherboard?
I bought a Gemibook Plus from eBay, JGeBPLIY1H231204569, and it came with a replacement power adapter of 19V, not 12V. The laptop no longer powers up with any adapters, 12V or otherwise. Nothing lights up. The battery is 8.6V, but has been failing to run the laptop for more than 10s, without being plugged in. I tried power reset, disconnecting the battery, etc. nothing works. I haven’t disassembled anything yet, but just the backing, so I don’t know if anything is burnt.
Can I replace the motherboard with an n150 version, that is fully compatible with a pcie SSD VNMe? I have an WD Blue SN5000 4TB drive, but you never gave me the bios configuration to make it work. The upgrade states it absolutely works with this drive, pcie 3.0x2.
Also the heatsink is different, but all the connectors look the same. Are they the same? And,
Could I get an n150 replacement motherboard with 16GB memory, and with heatsink kit. How much is it?
Main power rail shorted by the 19v adapter. If you know electronics you can fix it. Replacement by N150 should be possible. Good luck!
