Hello, I have tried everything in the bios to enable the tpm but windows says “Compatible TPM not found”, Can someone help because im trying to play valorant and i cant because it needs tpm 2.0 and i cant enable it!!! If so is there a way to flash the bios?
Hi, what does “testing everything in the BIOS” mean ?
Can you upload photos of the TPM configuration ?
Have you changed any BIOS settings?
You can contact support or get help on Telegram.
@manonegra222 Can you help here, please ?
