My larkbox pro sound not working in windows only.
I try in Ubuntu and its work directly out of the box.
I try to install the sound driver but without luck.
Can you please guide.
it has been like that for so long, lack of drivers etc. you can expect this kind of support from a cheap and irresponsible company/brand. i’m not even surprised you didn’t get a reply to your question after 10 days. good luck for that. email them and you could get a template reply.
Unzip this and update driver manually from device manager. It works for me.
It also works on larkbook.
Thanks!
