A couple of days ago I received my MiniBook X U300 and directly I noticed the fan is spinning up intermittently every 10 seconds. I tried lowering performance setting in the BIOS, with no effect. Temperature monitoring software report core temperatures between 43 and 47 degrees celsius so I see no reason for the fan spinning up.Is there a fan control program, i would rather have it spinning steady on a lower speed with less noise than this intermittent high noise situation.
In my opinion, if you buy a product and it doesn’t work properly, it’s better to return it.
Or
You can contact customer service and ask for an exchange.
