Minibook X U300 Linux graphics corrupted after booting
I got my U300 minibook last week and after confirming things were working on Windows I erased the disk and installed Linux.
To my surprise, the screen if often corrupted and unreadable after booting (making it sleep and waking up will fix the issue) but it is unusable this way. Don’t want to do this everytime I want to use the laptop.
Tried Fedora, Ubuntu, and Mint.
Any tips?
It can be good to have two systems on one disk.
The problem might be that you didn’t enable support for external controllers during installation.
There are some topics about installing Linux here on the forum.
You can look for help in the Linux forum.
You can also search on Google or use AI, as there might be some suggestions—for example:
how to install specific drivers in Linux
Thanks, but I don’t want or need Windows so it would be a waste of disk space.
What kind of external controllers? And enable support where? On the BIOS?
I already searched for this issue in the forum and everywhere else and didn’t find anything relevant to my issue, so that was why I posted. Maybe some incompatibility with the kernel on this chipset?
It may take a while after the release of new hardware to be fully supported by Linux. AFAIK Chuwi (and many other brands) does not contribute to Linux development.
With my MiniBook X N100 it took a year after its release before there were Kubuntu and Fedora versions that worked well.
That doesn’t help now, but you can decide for yourself how to cope with it.
Cheers, Jaap
thanks for the help Jaap, I was worried about this but yeah, no rush, perhaps a fix will happen soon.
I had some progress diagnosing the issue using AI, I’ll keep trying.
Here is the fix for Linux
