Problems with the fanspeed in Linux on aerobook plus
Hello! The second day I am struggling with the problem related to the fact that fanspeed does not react in any way to the load on the processor and video card. Coolers are just silent (well, or they barely move). Same problem on manjaro (with any DE) and ubuntu. Tell me where to dig?
you can try to use lm sensors and fancontrol.
Yes, I tried, tried using a variety of manuals, but either I don’t understand something, or the laptop configuration does not support software fanspeed control on lnux. Or is there a distribution kit in which this functionality is implemented?
Just in case, here are the command outputs:
sensors-detect
~ >>> sudo sensors-detect
sensors-detect revision Revision
System: CHUWI INNOVATION LIMITED AeroBook Plus [Default string] (laptop)
Kernel: 5.8.6-1-MANJARO x86_64
Processor: Intel® Core™ i5-6287U CPU @ 3.10GHz (6/78/3)
This program will help you determine which kernel modules you need
to load to use lm_sensors most effectively. It is generally safe
and recommended to accept the default answers to all questions,
unless you know what you’re doing.
Some south bridges, CPUs or memory controllers contain embedded sensors.
Do you want to scan for them? This is totally safe. (YES/no): y
Module cpuid loaded successfully.
Silicon Integrated Systems SIS5595… No
VIA VT82C686 Integrated Sensors… No
VIA VT8231 Integrated Sensors… No
AMD K8 thermal sensors… No
AMD Family 10h thermal sensors… No
AMD Family 11h thermal sensors… No
AMD Family 12h and 14h thermal sensors… No
AMD Family 15h thermal sensors… No
AMD Family 16h thermal sensors… No
AMD Family 15h power sensors… No
AMD Family 16h power sensors… No
Intel digital thermal sensor… Success!
(driver `coretemp’)
Intel AMB FB-DIMM thermal sensor… No
Intel 5500/5520/X58 thermal sensor… No
VIA C7 thermal sensor… No
VIA Nano thermal sensor… No
Some Super I/O chips contain embedded sensors. We have to write to
standard I/O ports to probe them. This is usually safe.
Do you want to scan for Super I/O sensors? (YES/no): y
Probing for Super-I/O at 0x2e/0x2f
Trying family National Semiconductor/ITE'... No Trying family SMSC’… No
Trying family VIA/Winbond/Nuvoton/Fintek'... No Trying family ITE’… No
Probing for Super-I/O at 0x4e/0x4f
Trying family `National Semiconductor/ITE’… Yes
Found unknown chip with ID 0x8987
Some hardware monitoring chips are accessible through the ISA I/O ports.
We have to write to arbitrary I/O ports to probe them. This is usually
safe though. Yes, you do have ISA I/O ports even if you do not have any
ISA slots! Do you want to scan the ISA I/O ports? (YES/no): y
Probing for National Semiconductor LM78' at 0x290... No Probing for National Semiconductor LM79’ at 0x290… No
Probing for Winbond W83781D' at 0x290... No Probing for Winbond W83782D’ at 0x290… No
Lastly, we can probe the I2C/SMBus adapters for connected hardware
monitoring devices. This is the most risky part, and while it works
reasonably well on most systems, it has been reported to cause trouble
on some systems.
Do you want to probe the I2C/SMBus adapters now? (YES/no): y
Found unknown SMBus adapter 8086:9d23 at 0000:00:1f.4.
Sorry, no supported PCI bus adapters found.
Module i2c-dev loaded successfully.
Next adapter: Synopsys DesignWare I2C adapter (i2c-0)
Do you want to scan it? (YES/no/selectively): y
Adapter doesn’t support all probing functions.
Some addresses won’t be probed.
Next adapter: Synopsys DesignWare I2C adapter (i2c-1)
Client at address 0x2c can not be probed - unload all client drivers first!
Next adapter: SMBus I801 adapter at f040 (i2c-2)
Next adapter: Synopsys DesignWare I2C adapter (i2c-3)
Next adapter: i915 gmbus dpc (i2c-4)
Do you want to scan it? (yes/NO/selectively): y
Next adapter: i915 gmbus dpb (i2c-5)
Next adapter: i915 gmbus dpd (i2c-6)
Next adapter: AUX A/port A (i2c-7)
Next adapter: AUX B/port B (i2c-8)
Now follows a summary of the probes I have just done.
Just press ENTER to continue:
Driver `coretemp’:
  • Chip `Intel digital thermal sensor’ (confidence: 9)
Do you want to generate /etc/conf.d/lm_sensors? (YES/no): y
Created symlink /etc/systemd/system/multi-user.target.wants/lm_sensors.service → /usr/lib/systemd/system/lm_sensors.service.
Unloading i2c-dev… OK
Unloading cpuid… OK
sensors
~ >>> sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +44.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +42.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +42.0°C (high = +100.0°C, crit = +100.0°C)
pch_skylake-virtual-0
Adapter: Virtual device
temp1: +42.0°C
iwlwifi_1-virtual-0
temp1: +57.0°C
BAT0-acpi-0
Adapter: ACPI interface
in0: 13.99 V
pwmconfig
~ >>> sudo pwmconfig
pwmconfig version 3.6.0
This program will search your sensors for pulse width modulation (pwm)
controls, and test each one to see if it controls a fan on
your motherboard. Note that many motherboards do not have pwm
circuitry installed, even if your sensor chip supports pwm.
We will attempt to briefly stop each fan using the pwm controls.
The program will attempt to restore each fan to full speed
after testing. However, it is ** very important ** that you
physically verify that the fans have been to full speed
after the program has completed.
/usr/bin/pwmconfig: There are no pwm-capable sensor modules installed
On another forum I read that if the output does not display the rotational speed of the coolers, then all these manipulations do not make sense
Try, Manjaro XFCE 20.1 Linux x64
For people who want a reliable and fast laptop.
This edition is supported by the Manjaro team and comes with XFCE, a reliable desktop with high configurability.
Xfce is a lightweight desktop environment for UNIX-like operating systems. It aims to be fast and low on system resources, while still being visually appealing and user friendly.
Download from here:
https://manjaro.org/download/#Official
Off topic. I wrote that the problem remains on Manjaro (KDE and GNOME edition). The desktop environment plays no role in this case, including XFCE.
