UBook 11.6" USB-C charging
Is charging this tablet over usb-c port supported? I read various statements on the Internet, but would like to get an authoritative answer.
Thank you,
–Alex
This is not supported.
I bought it also because of this option.
In the presentation webpage it is stated that it is supported…
see:
Versatile Interface,
All In One
UBook has versatile USB Type-C interface.
It sets transmission data, charging in
one. It can also connect Hub to more
extensions.It almost meet the all peripheral
connection in the market.
https://www.chuwi.com/product/items/Chuwi-Ubook.html
As the item has still to be delivered. It is not possible then to charge it via USB-C?
How can I proceed?
i charge with usb C , and no problems
@SunLine, do you have the Ubook 11.6 (not the pro one)?
Aka this one -> https://www.chuwi.com/product/items/Chuwi-Ubook.html
Can you share wich kind of adapter are you using (Volts / Ampere)?
45W , yes 11’6 . You can buy it for 10 dollars in Aliexpress
