CHUWI Launches AuBox Mini PC in Europe.
Powerful & Compact: CHUWI AuBox Mini PC
Featuring an AMD Ryzen 7 8745HS , 16GB DDR5 RAM , and 512GB PCIe SSD —built for high-speed gaming and multitasking.
Power All Needs
Performance Redefined
Powering the AuBox Mini PC is AMD’s Ryzen 7 8745HS - an 8-core/16-thread Zen 4 beast with 4.9GHz boost clock, 4nm efficiency, and 65W TDP for seamless gaming, multitasking and creative workloads.
Advanced Radeon 780M Graphics
The AMD Radeon 780M iGPU features RDNA 3 architecture with 12 CUs clocked up to 2.6GHz, delivering entry-level discrete GPU performance with hardware ray tracing for immersive visuals.
Quad 4K Display Support
The AuBox 8745HS supports quad 4K displays via USB4/Type-C/HDMI/DP, delivering buttery-smooth 4K@144Hz visuals for gaming and productivity.
Upgrade-Friendly
Ultra-compact at 154×152×45mm and just 740g, the VESA-mountable AuBox Mini PC enables clean setups while offering expandability up to 64GB RAM and 2TB SSD for future-proof performance.
Comprehensive Connectivity
Packed with 12 ports including 40Gbps USB4, dual 2.5G Ethernet, Wi-Fi 6, USB 3.2, DP 1.4 and HDMI, this compact powerhouse delivers ultimate connectivity for any setup.
Windows 11 Pro Pre-installed
The AuBox Mini PC comes ready-to-use with Windows 11 Pro, delivering enterprise-grade security, virtualization, and productivity tools for instant professional computing.
| Model | AuBox |
| CPU | AMD Ryzen™ 7 8745HS |
| (8 Cores, 16 Threads, 4 nm Process, up to 4.9 GHz) | |
| GPU | AMD Radeon™ 780M, hardware ray tracing |
| Memory | 16GB DDR5 5600MHz |
| (DDR5 Dual-channel SO-DIMM Slots, Expandable up to 64GB) | |
| Storage | 512GB PCIe SSD |
| (2× M.2 2280 PCIe 4.0 SSD Slots, Expandable up to 2TB) | |
| Operating System | Windows 11 Pro |
| I/O Ports | 1× Full-featured USB 3.2 Gen 2 Type-C Port |
| 1× USB 4 | |
| 2× USB 3.2 Gen 2 Type-A Ports | |
| 2× USB 2.0 Type-A Ports | |
| 1× HDMI 2.1 Port | |
| 1× DisplayPort 1.4 Port | |
| 2× 2.5G LAN Jacks | |
| 1× 3.5mm Audio Jack | |
| 1× DC-In Jack | |
| Display Support | Simultaneously supports up to four displays: |
| One display with up to 4K resolution at 144Hz over the USB 4 | |
| One display with up to 4K resolution at 144Hz over the full-featured USB-C | |
| One display with up to 4K resolution at 144Hz over DisplayPort 1.4 | |
| One display with up to 4K resolution at 120Hz over HDMI 2.1 | |
| Wireless Connectivity | Wi-Fi 6, Bluetooth 5.1 |
| Ethernet | Supports 2.5Gbps |
| Power Adapter | 19V/6.32A, 120W Power Adapter |
| Size | 154 × 152 × 45 mm |
| Weight | About 740g |
Availability
You can buy this fantastic Mini PC by visiting the Europe website or Global website.
