Hello, where can I download the bios for
LQ64G42180102824 and
LQ64G42171101898
A lot of thanks in advance.
hello, do you need system or driver, thank you
Hello, please don’t modify the BIOS. Making changes will make it unusable. This one is under our control. Thank you
Hello folks, I need the bioses because the two tablets are broken. So if you can help me out here I would appreciate it very much.
Kind regards.
