Where i find new charger batter for my CoreBook X? Please
Hello Moniq,
You need the charger or the battery?
Regards,
ML
Hello
For the Charger, you may search for one with 19v output and at least 3.25A as the original.
I would recommend, since this device can be charged by USB-C, to look for a USB-C Charger of at least 65W because then you can use for the laptop and for any other device you have using USB-C.
If you search for USB-C Charger PD 65W in Amazon, etc you must find some good options from Anker, Baseus, Blitzwolf and other known branches.
Thanks so much for the reply. Could you recommend me a page where I can buy?Because these are the days that I can’t use pc and I need it urgently for work. Thanks again
I believe the best and quicker is to go to Amazon(es, fr, it… depending of where you leave) to get it.
A good option from Baseus
Another one,
Others simpler but that you cant use with your phone or other cables
Or with detachable cable
It is universal charger, 65W USB C Laptop Charger Compatible with CHUWI CoreBook X 14",Type C Power Supply Adapter
You may also check the replacement battery for CHUWI CoreBook X 14"
