Chuwi Etherner driver
S/N ZRZBOXIY1H230400187
CHUWI Mini PC Gaming AMD Ryzen 7 5800H
Amazon
22/6/23
I lost my Ethernet drivers. What adapter does the Mini PC use — Realtek or something else? The drivers you previously provided do not work. Where can I download the installation file?
You can download the drivers from the Chuwi website.
Where?
I cant update drivers, because iv lost ethernet driver. So I cant use inf-file
just add .com, go to support
What is this? Can you give direct link to me?
I don’t have it, I just know how to search for it.
Come on, man, it’s not hard to Google it.
Who are you? I can found only: RZBOX5800H-drivers. Those dosnt work. There are not .exe-files for ethernet.
I’m a user like you, trying to help.
There are several ways to install a driver.
Thank you for the help. I’m familiar with the installation process. I’m mainly interested in which adapter is used in the device, its specifications, and also the installation file.
I unzipped my device drivers and found a folder: Lan
which I assume should be Ethernet
A simple question. Which manufacturer’s Ethernet drivers are in use? Realtek, Intel, AMD…?
Drivers here, i checkes if you enter the SN
THose drivers dosnt work. Which manufacturer’s Ethernet drivers are in use? Realtek, Intel, AMD…?
Which manufacturer’s Ethernet adapter are in use? Realtek, Intel, AMD…?
Solved! Shut down the computer by holding the power button for 30 seconds. Restart the computer. All Ethernet, Wi-Fi, and other drivers have been restored. And everything works.
unpluged the cable of adapter of current 5 minutes and then conected again , and all works fine, you not need reinstall nothing
