Hello. My laptop after turning on can not boot the system. It shows an error and then turns off. At the repair shop they told me that I need to replace the motherboard. Where can I buy a motherboard for my laptop and is there another solution to the problem?
It will cost you more expensive to buy the motherboards and reinstall everything than buy a new laptop. If its an old model like i3. i5., N100 we dont have replacements anymore. So would be quite hard for it.
We apologize
