Chuwi Model: CW1515, Intel Inside doesn't boot
Hi10 Q64G42160402139, bought it in like 2017-2018, in a online indonesian online store called Jakarta Notebook
doesn’t boot anymore and I dont remember alot on what happend before, before it stop booting it either had an update or a crash and after a while I tried using it and when i turned it on it flashed the bootscreen (running win10 btw) and then it just crashed, tried again nothing appears this time, and one time I tried turning it on it sounded like a high pitch noise like it was gonna blow up.
Does anyone know if its like a malfunction from the software or hardware? or myabe also a fix for it.
I can’t tell you what’s wrong with it.
What I can tell you is that after 7 years, I think it needs a replacement.
