Corebook X doesn't Power Hp
Hi!
After a pause of summer holiday that i didn’t use the Corebook X ( about 2 weeks) my Corebook X does’nt power up!
When i connect the orginal charger nothing happens: the led power is turned off.
Anyone can help me?
Hello maupap,
Try charge using a USB-C charger with at least 65W to check if red light turns on to indicate charging.
Regards,
