CoreBox 5th Gen Factory reset and upgrade to W11Pro
Hi, I purchased a used CoreBox 5th Gen. Is possible to factory reset it and upgrade it to Windows 11 Pro? Thank you very much.
You can download the operating system and drivers from the Chuwi website, under support, downloads.
Is possible tu upgrade from W11 Home to W11 Pro with new Activation Key?
If the Pro version isn’t available on the Chuwi website, you’ll need to download the operating system from the Microsoft website and use their software to create an installation USB drive.
You can use the Snappy Driver Download application to install the drivers.
