Drivers For Corebook X
Hi, i had to get a new hardrive since my old one was damaged, after installing windows 10 on it, wifi and touchpad do not seem to work. Could i get all the drivers for Corebook X
Model No: ZCoreBDW1H230400603
I made the bootable windows 10 drive from a different laptop, so if that could be the issue let me know. Thankyou.
Its better you install the windows that came with the laptop
You can find it here, i tried and it worked
Awesome, worked perfectly. But now my pc is running windows 11. I would ideally use windows 10 (personal preference)
Can I create the windows 10 bootable usb from my chuwi pc? Like will that work or will that be buggy like before.
Thankyou
спасибо, я очень долго искал драйвер для Wi-Fi и BT
