hi guys, i tried to update but now way ! installing the driver was impossible. i tried the signed one found here : Download Mediatek (MTK) VCOM, CDC, USB & Smartwatch Drivers but it doesnt help. sp flash tool once saw the tablet but stopped at the end. now it does not see the tablet any more. any help ?
As wrote [hebeda], you have to temporarily disable the driver signature check in order to install the drivers. Look at this tutorial and try option 2 (āUse an Advanced Boot Optionā) :
Also maybe you should uninstall the signed driver first before installing the drivers provided by Chuwi. This way you can avoid a potential driver conflict.
I hope it helps!
any new easy ways to update to android 11
Dear Management thank you so much for your very very very good and detailed description of the firmware upgrade process steps!
Two suggestions:
I used the version of the tool: SP_Flash_Tool_v5.2148_Win
I re-named the folder of the firmware (deleting the chinese texts and reducing the lenght of the text). In this way it accepted the file āMT6771_Android_scatter.txtā
Hi.
Finally i update mi Hipad Plus.
Thank“s to @hebeda and @bk8 for the tips!
For those who have driver problems, i suggest install this drivers ( https://drive.google.com/file/d/1TPbW-v9-yOrzH15OaHmsPQad420mULeF/view ). I install those and my problems are solved!!!
Sorry my english.
