Hardware upgrade
Hi, I have an AeroBook Pro and I am happy with it.
It was at first a temporal solution but now I would give it more work.
So I would like to replace the SSD and put more memory.
1.- Is it possible?
2.- If possible, which SSD and memory can I put it in?
Thanks!
Hello fpuertas, welcome to the forum.
Upgrade options are limited to the M.2 2280 SATA slot only as RAM is soldered.
You should look for SSD with M.2 slot and SATA technology, meaning, NVME won´t work.
Regards,
Thank you for your response.
Do you have any recommendation?
Thanks again.
Hello fpuertas, not sure which one to recommend. So far I know, Kingston ones are well evaluated these days.
Regards
Thank you very much.
