HELP I NEEDED UPDATE BIOS FOR FIX BLACK SCREEN PROBLEM
Hi there.
Like many in the forum, I bought a CHUWI Corebook Pro i3-6157u. After a short time I had the “black screen” problem and I understand that a BIOS update may fix it. On the internet there are many reports that the version that this product comes with by default usually generates these problems.
If anyone knows where I could get an up-to-date view of it, I would greatly appreciate it.
I currently have this version of the BIOS: JXX-BI-13.3-WU133SR200-034-K American Megatrends 09/09/2020
Have you solved?
Send your SN
