Hello
I am trying to using active HDMI to Displayport convertors to connect the HeroBox to a Displayport monitor but I am severe problems. I get a video signal at 2160p/60Hz correctly and Win10 displays correctly but …
- I lose all bluetooth connectivity
- Windows slows down
- Task manager is no help in locating the problem process because it stops updating and refuses to shutdown
- After a short while I get a BSOD “Driver State Power Failure”
If I connect the HeroBox directly via HDMI to the same monitor it works perfectly!?!
I have tried two different convertors (one from Foinixx and the other from Benfei). Both give identical results.
Any ideas?
PS: the reason I am trying to the use the Displayport input on the monitor for the HeroBox is because I am planning to get a KVM switch for the monitor.
