Hi10 Pro ; How to enable access to guest user
How can I enable access to install unknown apps for my guest user? It just say that the app (chrome) is disable by the admin. I tried to enable it, but nothing’s works, I also tried checking the modifying system setting if the app was disable, but it’s not- it is enabled in the admins profile
It is Hi10 pro or hi10xpro? Didi you search on google how to do that? because it does not seen about the tablet
Hello, yes I already search it and I already watch bunch of tutorial how to enable it, I’m using the Hi10 pro
@manonegra222
