HI10 Pro WIFI Problem
WIFI DOES NOT WORK ON WINDOWS, CANNOT FIND ANY NETWORK, WINDOWS DIAGNOSTICS SAYS THERE IS AN ACCESS PROBLEM OR WIRELESS CARD, HOW CAN I SOLVE IT? IT IS IMPOSSIBLE TO USE THE INTERNET AT THE MOMENT. I HAVE A CHUWI HI10 PRO HQ64G42171001825
THANK YOU IN ADVANCE
Try to reinstall driver
And try to set wi-fi adapter settings in “properties->advanced” like this:
Antenna Diversity - Enabled
Bandwidth - 20_40MHz
Multi-Channel Concurrent - Disabled
Roaming Sensitivity Level - Disabled (or low)
Wake on Magic Packet - Disabled
Wake on Pattern Match - Disabled
Wireless Mode -IEEE 802.11 b/g/n
How can i install that pack?
Unzip files to any folder
Go to Desktop and press Windows + X button and select Device Manager.
In Device Manager, you have to find the Network Adapters section and inside that, you will find your WiFi Driver, you have to right-click on that and select the Uninstall device
Check the box “Delete the driver software for this device” and click Uninstall.
Then click Action->Scan for hardware changes, find wifi adapter, go to properties->driver->update driver->browse my computer->select folder with unzipped files, check the box “include subfolders” and click Next.
i did it, but shows a message " the latest driver for this device is already installed"
Try this installer https://www.realtek.com/en/agree-to-download?downloadid=fdb4737f020f36b2bed9701819db213e
or
https://dl.dell.com/FOLDER02625551M/2/3845_Network_Driver_PPJT0_WN_3007.7.915.2014_A01.EXE
nessuno dei due link ha risolto il problema, il primo link non si apre, mentre il secondo link non è compatibile con il mio dispositivo
