Hi10max Windows LE Audio not Supported
I have Hearing Aids, when I try to connect them to the HI10Max I get “ your PC doesn’t support LE Audio,
Please Advise
Can someone from Chuwi please respond to this?
Have you searched on Google ?
Have you reinstalled Windows or changed the Windows version ?
What type of headphones are you connecting ?
The same thing happens when connecting wired or Bluetooth headphones ?
They’re Hearing Aids, Starkey AI 24, I’m on the latest version of Windows 11,
I’m thinking Chuwi is using an older Intel CPU
The computer had Windows 10 when you bought it ?
No, it’s less then a year old, and came with Windows !! installed
