Which options should i change on BIOS so i can boot from network by PXE with an ethernet USB adapter?
You can follow these steps:
- First, start the machine and click “F10” to enter the BIOS interface.
- Next, click “Boot Options” in “System Configuration”.
3, Select “PXE Internal NIC Boot” from the “Boot Option” TAB and save to exit. - When restarting the computer, click “F9” and select “Notebook Ethernet”.
There´s no “PXE Internal NIC Boot” option under System Configuration menu
