Please provide HiPad X Android 11 firmware
Send your serial number please
Hi
I want also Android 11. Where should I send my serial?
THanks
here…do not worry no one will do anything on your computer
Hi I also want android 11 on my HiPad X
HipadXQ128G21030568
Hi, I want the last update please, still on android 10 with 5 august 2021 security update …
mt8788_20210202_20210907-1533
serial : HiPadXQ128G210504707
Thank you
Do you have any answer about the firmware ?
There is no Windows 11. no update after yours
It’s not Windows but Android.
No more OS or security update ?? 2021 it’s a security bu775hit !?
I buy it in november 2021… there was an error isn’t it ??
Sorry yes, i send so many files, that i get messep up
As i said many times in the forum, we produce in Batch, So we develop a software for each batch, unless there is some important thing to solve we normally dont release OS updates. I asked again and we dont have Android 11 for this model ![]()
So what you posted above is not Android 11 for HiPAD X ?
So …
I can’t believe I bought this in 2021 and cannot have newer patches …
Come apps doesn’t works, and this is a security breach in my network…
What can I do with this ?!
