Pilfo
January 25, 2025, 3:46pm
1
Hi. Need some help Hard reseting my tablet. Buttons combination doesn’t work. Is it possible with flash? Need direcions. Thanks
S/N CHipXpEB10231002039
Pilfo:
CHipXpEB10231002039
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Restablecer tablet CHUWI HiPad XPro.mp4 - Google Drive
Use this firmware to hard reset Chuwi HiPad XPro S/N: CHipXpEB40231000448
Pilfo
February 15, 2025, 9:54am
5
You must use specific firmware for your tablet. Cannot use any firware that was not sent to you according by your tablet S/N.
I used this firmware to flash my unit and is Working just perfect.
Give me your Serial number
Serial number CHipXpEB40231000448
I’m having the same exact issue. Can anyone help!?!!
efcomewell:
CHipXpEB40231000448
S/N : CHipXpEB10231000391
I’m having the same issue with HiPad XPro SN/ ZHipXpEY00230314234 please help
Thank you so much. I followed the instructions step by step and it works now. Gracias
Hi,need firmware for HiPadXPro S/N CHipXpEB30231000039
Och
October 20, 2025, 10:23am
19
Need help! ZHipXpEY00231203446
HipadXpro T616. My son forgot his password. Please help! S/N: CHipXpEB30231000245
I have no idea how old your child is:
the password should be saved or written down.
You can download the operating system and drivers from the Chuwi website, in the “Support” and “Downloads” sections.
If they are not available for download, You should contact Chuwi customer support: service@chuwi.com
