Larkbook drivers
Hi
I’m looking for the drivers section of the larkbook for windows 10 because I tested my external screen which was not on the good resolution and I suspect the drivers not to be installed.
Any ideas ?
Thank you
This is all the drivers of larkbook.
I hope it can help you
Thank you a lot !
There are a lot of files though I don’t know which on to use …
Could you please share the good one ?
And also a procedure to install the driver please ?
Thank you !
Hello
Please tell me the exact model and serial number of the computer, and I will send you the whole system software to reinstall the whole system. How do you feel?
thank you
Hello
The following is a tutorial on system files and reinstallation.
Thank you for your letter and wish you a happy life.
  1. Lista de elementos
I don’t have the driver for the multimedia audio controller, please send it to me.
i want to have full driver of larkbook LarkBQ256G21092302. I cant take audio work after install any driver. Thank you so much
Pudieran pasar el driver del touch de la pantalla porfavor TYPE:CWI509
Larkbook 13.3…sdasdasd
