my Hi10 XPro 2023 Always Restart.
Give me your serial number, so i can send you the files to reinstall
JH10XpAB50240108832
I try your tutorial ( volume - and connect type c ) but i can not connect to research download app my pc run on windows 10
@manonegra222 why would it be?
I have the same problem
Can I use the same files?
give me your serial number and ai check
YH10XpAB10230500215
Thanks ![]()
Many thanks!! ![]()
serial number : YH10XpAB20230702537
Thanks.
Hi10 XPro
Hello, I am having a problem with my new Hi10 XPro. It is always restarting and show only the Chuwi. Serial Number: JH10XpAB50240308611
Please help.
@benprodserv you can install from the previous post
Please send the relevant files and steps to re-install
My problem still not resolved after flashing. The tablet rebooting to the Chuwi logo and get struck there. Please help
Then it may be hardware problem.
You need to send to repair.
Rellena este formulario y mis compañeros te contestan
I have the same issue with my Hi10 XPro. It always restarts several times after waking up and every app crashes on first use.
Serial is YH10XpAB20230703817. Please send software link. Thank you.
