I have a tablet Hi10 plus with android 5.1 (serial LQ64G42171101695) that does not upgrade anymore.
I would like to install the last compatible Android official version (and that supports updates), is it possible ? can you advise me one ? a possible tuto ?
Thank you a lot.
Best regards
Sabri
