Rear 3.5mm universal audio jack
Hi, is possible to connect Active Computer Speakers to the rear 3.5mm universal audio jack?
What’s the problem ?
I asked this because usually the audio output connector is marked with a green colored label but on the CoreBox 5th there is no colored label.
I would like to connect my PreSonus Eris 3.5 speakers to the audio output with the RCA cable.
How many 3.5 mm connectors does your computer have ?
CoreBox 5th (i5 13500H) have only one black audio connector
For these cases, always keep the user manual that came with the device or check the Chuwi website for specifications.
You only have one connector: the audio output connector.
