Reset my CHUWI HiP AirQ tablet to factory settings and forget the PIN code
I restarted my tablet to factory settings and it asks me for the PIN code which I don’t have.
if it’s an android device, resetting should have removed your pin. i hope you setup your pin yourself with a google account, then these options are available:
If you’ve forgotten your Android device’s PIN, there are several methods to help you regain access:
  1. Factory Reset: This method will erase all data on your device, so use it as a last resort. To perform a factory reset:
  • Boot your device into Recovery mode (check your device’s manual or manufacturer’s website for specific instructions).
  • Select “Wipe data/factory reset” and confirm.
  • Your device will be restored to its factory settings, and you’ll need to set up a new PIN or password.
  1. Forgot PIN Option: If your device is running Android 4.4 or later, you may have the “Forgot PIN” option available:
  • Go to the lock screen and enter an incorrect PIN five times.
  • Your device will prompt you to select “Forgot PIN.”
  • Follow the on-screen instructions to reset your PIN using your Google account credentials.
  1. Use Find My Device: If you’ve enabled Find My Device on your Android device, you can use it to remotely reset your PIN:
  • Sign in to your Google account on another device.
  • Go to the Find My Device website or use the Find My Device app.
  • Select your device and choose “Lock” or “Reset lock screen PIN.”
  • Follow the prompts to reset your PIN.
I bought it second-hand and I don’t have access to the account with which it was set up the first time. I already factory reset it several times and it keeps asking for the pin code. What else can I do?
go back to the seller?
DIme el número de serie para que puedas instalar de nuevo el sistema
HiP AirQ128G21092463
intenta con esto:;
Sorry, I have tried this method, but the charging indicator that appears is a green battery image. what should i do?
@manonegra do you have a manual for this tablet?
Show me how to reset my chuwi Hipad X
