Добрый день!
Как мне выключить порты USB после выключения компьютера
В BIOS такой возможности нет или я ее не увидел.
Спасибо за помощь.
Good afternoon!
How do I turn off the USB ports after turning off the computer
There is no such possibility in the BIOS, or I did not see it.
Thanks for the help.
maybe @manonegra222 can help?
After the computer is turned off, the USB ports continue to work. How can they be distinguished?
Thanks!
I will ask also tech tomorrow .
They are making some tests, like changing the EC software. If they confirm i will send to you.
Would you please tell me the Serial Number of your model? so they can register this?
ZCoBoxIW1 H221100456
понедельник, 19 февраля 2024г., 17:39 +03:00 от Maria Isabel via CHUWI | Official Forum notifications@chuwi.discoursemail.com:
They are still trying several things to see how it can be shut down. I will answer back when they give me the solution
Hello Tech finally developed a patch for this.
Here is the file. You guys try it and see if works so other users know.
