My internal entenna is broken. I bought an usb wifi. In windows the driver is installed. But how do I install the driver in Android. I’ve read that this must been written in the flash/kernel?
But where do i have to put the extra code and what for code?
I found on the forum HQ64G42170705940
Ok thanks for your answer. The one i bought has the following driver in windows: “802.11n usb wireless Lan Card”.
So I can’t use this one with android? Isn’t it possible to rewrite the bios so that this driver loads in android?
