can not remember pin to get into tablet. need to factory reset.
In this case, you can only reinstall everything from Zero. If you give me your serial number i will give you the files.
all that is on the case is type:cw1559 there are no serial numbers on the outside of the tablet
would you please make me a picture of the back? or do you still have the box?because cw1559 is not enough for me we have many batch of serial numbers with different software ;(
i need to see the Serial Number. Can you check in the box¿
i did not keep the box.
Then would be hard to give the the files to install if i cant know the Serial Number.Did you buy in Chuwi Store? maybe with the order number i could check which one was sent to you.
i bought through newegg but from the “FROM CHUWI OFFICIAL STORE”
Thanks for the tip.
HEre:
OS
how to:
