Hi everyone. I am wondering how the image quality of AeroBook camera is so bad. It’s grained and blurred. Also with very good lighting conditions (daylight), the image looks dark, the background is almost black, colors are also bad. It’s impossible to do a conference call in these conditions. Is there something I can do??
Thank you for your help.
The front cameras of the devices are intended for video conferencing and usually do not have a high quality since higher quality is associated with higher data consumption and worse quality since with much data it is easier to cut or freeze. The better the lighting, the better the final result, but without major improvements.
You can write “camera” in the lower left box and go to the camera settings where you can make some adjustments to the image quality in case they improve the experience
