Aerobook Plus dead screen
Aerobook Plus Q25G256G20050524 about 4 years old.
Dead screes.I don’t see the chuwi logo. I’m using it connected to an external HDMI display. It started not turning on but then started working again after a few reboots. Now the screen shows no signs of life. I disassembled it and tried to test the connectors between the motherboard and graphics card with a tester but it’s complicated.
I could tell you to send it to repair, but do not know if its would be worth it as you will need to pay for the repair.
It is an old product and we dont have a screen replace right now i just asked
it may be worth trying replacing the connector between the motherboard and screen (provided it is available)?
In the end I decided to replace it.
The new computer will certainly not be a chuwi.
It is the one that
lasted the least and gave me the most problems. I just bought the discovery that it had a processor that has been out of production for several years.
Problems with the USB ports, the screen panel that is disassembled and broken, excessive heat when using 3D applications, problems with the ssd memory, the battery charger that is broken, poor reception of weak wifi signals. I don’t understand how chuwi can have the courage to call new computers on sale “pro” when they have cheap processors.
bye bye CHUWI
