Android image for CW1526 HiBook Pro (HiB PQ64G)
Hi everyone,
My tablet is dual boot for Windows and Android but it boots Windows only.
How can I load Android on it and then boot Android only?
Thank you.
you tablet is Hibook or Hibook Pro¿ can you make a picture of the back?as it is quite old i need to check exactly
Try this:
Thank you for your reply.
It’s model is CW1526, HiB PQ64G45160600943
I download this Android image file but I don’t know how to upload it to my CHUWI.
@manonegra probably can help you because is an old model
I downloaded the Android image, but how can I upload it on my HiBook tablet?
Any help is welcome.
@ChuwiESnotactive @manonegra222
Try these ones is explained here
Thank you for your response.
Those files do not contain esp.img due to my screenshot warning.
What should I do?
@manonegra222 how can i solve this?
