Hi @manonegra222
My tablet model is CW1526, HiB PQ64G45160600943 .
There is no operating system on it and its 64GB memory is formatted completely.
How can I install just Android on it?
FYI, I read this tutorial already: ChuWi Hibook Pro dual system flash tutorial
At the BIOS flashing, I can not find the EFI folder on your flashing files, (As shown in your tutorial) and my tablet did not boot correctly for flashing the BIOS. Where can I find your complete files for flashing?
These aren’t files fir the Hibook tablet, take care
The HiB tablet is Hibook, not Hi8
Thank you for your helps.
Where I can download the official files for ROM containing gpt53 ?
Also, my HiB tablet does not have any OS (even Windows), How can I flash it to Android only?
I appreciate your support.
Sorry my bad… too many files everyday.
Do you want to have Android and Windows or just Android?
I’m Working, didn’t forget you
@manonegra222
Check if these files are ok. I asked for them.
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
