Audio driver problem in GemiBook Intel Celeron Windows 11
After installing Windows 11 on my Gemibook, the audio driver is showing problem (no audio device). My Gemibook Processor is “intel(r) celeron(r) j4125 cpu @ 2.00ghz 2.00 ghz”. Could you please suggest me how to install audio driver in my PC?
The drivers can be downloaded from the Chuwi website, Support, Downloads.
or
You can also install the Snappy Drivers Download app.
If you can’t find the correct driver, you can temporarily use a USB audio adapter (cheap and plug-and-play) while sourcing the proper OEM driver.
