i would like to buy chuwi lapbook pro 14.1 battery online ?
You can find it in Aliexpress, but first you must open the laptop and check the voltage and power of the battery as well as the dimensions
I will search on aliexpress thank you
I do too. Will Search again.
You can also try searching on amazon. But i suggest that you should see what the battery issue is. You need to change the battery.
