Support can share original and first bios for Aerobook Plus 16gb Ram?
The time to boot is very long
send the Serial number please
AePlusQ256G20052762
We do not recomend installing bios it could break the computer:
I have flashed this bios. 1 minute to boot. very very bad. Can u share me the official factory bios (the first one)
This is the Bios that came with the laptop, there is no other Bios…
Yes, but the time to boot is very long. How to set correctly?
Hi, can you try to send me the previous bios file? I would try rollback on sklu 0.05 (now on 0.08). please.
Cheers
There is no previous bios file, i mean that is the one that came with your laptop, if you install another may completely break the computer.
