Hello, Chuwi Gemibook Plus N100 16/512 HGeBPLIY3H240908137,
please specify how to enter the Bios Advanced-menu.(BIOS InsydeH20 Rev. 5.0)
thanks.
thanks.
You can find a tutorial on YouTube
это видео не работает для CHUWI
или снимите такое видео на таком же Laptop
What problem are you having with your computer ?
You write to me in a language I don’t understand
YouTube videos do not work in CHUWI
record such a video on chuwi gemibook plus
128mb GPU is very little with 16gb RAM
in some graphics programs, the image freezes
I do not play games)
If you have insufficient graphics memory, you need to replace the graphics card
Or
Install more RAM.
I’m sorry???
Intel(R) UHD Graphics 128mb
in the BIOS, set to 128-512 MB
The N100 UHD graphics use main memory(16GB)
why is it only 128 mb in the settings?
Why are you responding, but there are no real answers?
you can write how to unlock the BIOS Advanced-menu on my Chuwi Gemibook Plus N100?
This is a user forum; no one from Chuwi monitors it.
The only one who gives real answers is Chuwi
Что ты лезешь в биос в системе тебе сколько показывает 16гб если сам в настройках натупил скинь до заводских настроек восстановлением с кривыми руками лазить ненадо.
