Hi All!
Glad to become a member of this community
This night I turned on night mode and it caused the tablet hanging. So I restarted it by long press on power button. After that the screen stays black. I can reboot by long press on power or power+volume and it buzzes loudly when it reboots. When I connect to windows with USB cable, the tablet is seen as “unknown device”.
So I installed the tool which I found in the neighboring topic, watched the tutorial, but I don"t have the right firmware. I don"t have the serial number unfortunately, it was probably on the box which I threw away.
bonjour
le probleme n est pas de votre manipulation vous faite l objet d un virus qui rend invisible votre ddure
il faut imperativement le remplacer vous ne pourrez pas corriger
cdt
Hello Marcel,
you might be right but I would like to try to rewrite the firmware first. The data is lost in any case and the warranty is over because it was bought in 2023.
Thanks anyway
As the screen stays balck, I don’t really know if the tablet is turned on or off. If I press power or volume, it’s buzzing. As I understand, it should be turned off, not powered at all during that flashing procedure. So I guess I have to wait a few days until the battery is discharged, right?
För att starta om helt måste du hitta det lilla hålet på surplattan å där ska msn sticka in den lilla stiftetet som följde med surfplattan så startar den om ca 5 till 10 minuter detta är bara ett tips mvh Åke
