Hi my tablet CHUWI HI9plus have a problem of fast discharging battery pass from 90% at 80% in 5 minutes and later closes now i have do a wipe data factory from the recovery menu but now in configuration of the new tablet the battery is a 50% and has constant bootloop problems.could i fix it by installing the latest firmware available? I tried to use the available version (my tablet has the red button and is 4 gb of ram and 128 gb of rom) but Flash Tool give back a error “The Loader Scatter File is Invalid” i used this version of firmware “CHUWI X20P_6797_8.0_4+64 Dual mipi_2K_3H2+3H2_20180820+CH1005-0420” and “SP FLASH TOOL” finally i have installed a MTK driver for my 64 bit system operative.
What should I do?
Hello
Please give me the exact model and serial number, and I will find you the exact system files and brush tools to send to you.
thank you
Hello
Cwi515 is not a serial number. Its serial number shall be on the SM card slot.
Hi9plusE128G1940573 it s ok?
Reading this on a new device, the only answer can be warranty. return for new item.
I have the same problem of bootloop and fast battery discharge.
Could you please let me know how I can fix this problem.
The tablet works if I leave it connected to the power.
Status
Status of the battery, network, and other information
Legal information
Model
Hi9plus
Android version
8.0.0
Android security patch level
June 5, 2018
Baseband version
MOLY.LR11.W1630.MD.MP.V67.2, 2019/06/14 19:05
CDMA Baseband version
SIXTH.CBP.MD.MP5.V72.2, 2019/06/14 19:08
Kernel version
3.18.60
tang@tang #1
Mon Aug 5 12:56:26 CST 2019
Build number
000623 release-keys
Custom build version Hi9plus_v1.0_20190807
