What should I do? My serial Number Is JCoBXpIY1H250900020
You need to explain more so we can give a diagnosis, because just stating the problem as it is, it could be hardware or software-related. You need to explain if you’ve reinstalled Windows or changed any settings, or if you’ve installed drivers from unofficial websites.
Hi, i didn’t install anything, i just start PC and cam doesn’t work. Error code 0xA00F4244 NoCamerasAreAttached. I tried ti install driver from chuwi site but nothing are changed. What can i do? Please help😊
When did you buy it ?
Did you search for the error code on Google ?
One week ago. Google tells to download drivers, i did It but doesn’t work
When you buy a device and it doesn’t work as it should the first time you use it, there’s only one solution: return it. where you bought it, ask the seller You have 14 days to return if something doesn’t work properly.
