i have a problem with my brightness settings. All of sudden my brightness just stopped working. It is at the lowest setting and it is realla hard to do anything at night because you just cant see.
I have tried to update the graphics card drivers and check the power option on windows but no luck so far. Does anyone know the solution for this problem.
Thank you for the help.
