does somebody know if it is possible to change the wifi-card of the Hi 10 X ?
Why you want to change it? Imo it is impossible cuz everything is soldered to mainboard. But you still can use WiFi USB dongle.
Thanks for the reply. Sad that the chip is soldered.
I want to change the card because the range of the WiFi is poor. At the moment i have a USB dongle but if i don’t have the keyboard with me i cannot plug this particular dongle in.
hmm i using linux and imo i have good signal. Could be better but is OK.
The problem of Wifi in Windows is usually solved by doing a system restore: startup, configuration, update and security, recovery, reset this PC
