Recently, CHUWI exposed a super Mini PC LarkBox, the world’s smallest 4K mini PC. It’s almost the size of an apple. With the Intel N4100 processor, 6GB RAM and 128GB SSD combination, it can suit a variety of use scenes.
An apple-sized mini PC
LarkBox is only 616143mm, weights at 127g, which can be easily packed and carried. It’s almost the size of an apple, lighter than most phones on the market.
Ultra-small size suits a variety of use scenes
LarkBox can suit a variety of use scenes with ultra-small size. As a daily mini PC, it can be placed anywhere and convenient to carry for work. As a home entertainment center, It can connect to 4K TV for high-definition movie watching. Install the LarkBox on the back of the monitor or TV via VESA international standard interface
to make it an All-In-One PC
Suit office work and entertainment perfectly
LarkBox features the Intel N4100 processor, built-in UHD Graphics 600 graphic card, 6GB LPDDR4 RAM and 128GB SSD. Meanwhile, it supports an additional 128GB MicroSD extension. It can decode 4K video smoothly. With a low power processor, standby power is only 5W. The active cooling fan design makes the model generate no significant heat under high load.
The smallest 4K mini PC
Expect for the small appearance, LarkBox also comes with great comprehensive performance. Its comprehensive performance is equivalent to a small desktop PC, which can provide a high quality experience for office work and entertainment.
More information about it can refer to the link.(Leave your email address so that we can send you coupons privately.)
