Chuwi corebookX pro i5 12450H wifi issues
Wi-Fi connection is lock is open when Wi-Fi is late connect but if lock my laptop screen with this time Wi-Fi smoothly connected once more problem in this laptop i am facing sound is not enough battery is enough for travling . graficcard only 128 mb how can i improve
@manonegra222
With the information you provide, we can’t determine if you’ve changed anything or reinstalled the system that might have modified the original Chuwi drivers and could cause conflicts that cause the devices to malfunction. Regarding laptop upgrades, these computers are called sealed because their hardware configuration is barely modifiable, as most devices are soldered to the motherboard. Only in some cases can you add a new storage drive and, in rare cases, increase the RAM. For this reason, it’s always best to analyze your needs and compare them with the computer you intend to purchase.
